RE: Contest Director Questions
Question #9 The Maximum take off weight of a model is ____lbs.,with the exception of models flown under Experimental Aircraft rules.
Answer is 55lbs. and is covered under General Rules
Question #10 __________ft. is the maximum altitude you may fly within 3 miles of an airport without notifying the airport operator?
Answer: 400 ft.
Also covered under the general rules
