RCU Forums - View Single Post - Which Size Vess Prop?
Old 09-24-2007 | 03:19 PM
Jaketab
Default RE: Which Size Vess Prop?
Thanks for replies. The DA 50 is well run in. The only 2 props I’ve used on this engine are the Bolly 22x8 and 23x8 on the 17.5 lb WH Extra.
The 23x8 Bolly seems to be just ever slightly too much load. So I’m looking for something in the middle of the 2 mentioned. The prop will soon be transferred to a newer version SD-Models 50cc Yak. I’m hoping the Yak will weight in no more that 16.5 lbs.
Jaketab
