RE: fuel shut off valve?????
carlos
did you install after the pump and filter, that looks like the small size festo not the size that comes from the uat to pump i was planning to put it in the same area as you did but i was reading the instruction on the uat and bvm says to put it between the pump and uat so that is the reason for this post and i see it to concern others too it is great to be able to help each other because we all want to succeed. did you get the hawk airborne yet...............
later
Arden
