RE: Atomizing Jets?
By the way, your pressure ratings are quite good. I used to move smoke through a solenoid valve off of pressure from the on board propane tank. Once I was out of smoke fluid, the remaining propane would flow through the system and burn up in an "afterburner" type burn off.
That pressure is about 40 PSI.
