RCU Forums - View Single Post - Hangar 9 Twist 3D Part II - Thread Continuation
Old 09-24-2007 | 09:59 PM
  #1388
linkadrip's Avatar
linkadrip
Default RE: Hangar 9 Twist 3D Part II - Thread Continuation
Well the heat gun method worked wonderfully. Come to find out the canopy was not that well glued on after all and would have probably ended coming off after enough of the oil from the fuel got under it. But within a couple of minutes it came loose with no problems. Of course i glued it on alot better then it was and if it has to be removed again it won't be that easy.
Barbie didnt get the job as a pilot all she did was complain about how cramped it would be in the plane. So Snoopy stepped up to the plate, said i can fly the plane much better then that blonde anyway. You would be taking a real chance putting the controls in the hands of that inexperienced pilot, lol. Of course Snoopy is a bit of a hot head and a little wreckless but seems to have a good flight record, been shot down a couple times but always seems to land without any major damages so he's got the job.
Have to at least make it intresting[sm=lol.gif]
So here he is trying it on for size.
ID:	769509   Click image for larger version
ID:	769510   Click image for larger version
