Switch
Another way..Locate a Dean's charging socket..Take a 3 pin Dean plug, connect the 2 close pins together..Wire the socket as a through connection to one of the battery wires...Pin in, ON, pin out, OFF...Cheap and positive...Only problem is when you forget to bring the pin.....
Pretty hard to reach ANY switch on a gasser in an emergency, although a toggle is the easiest...
