RCU Forums - View Single Post - Field box battery/glow plug charging question
Old 09-25-2007 | 10:59 AM
planer
Default RE: Field box battery/glow plug charging question
I have the Power Panel II with a standard Panel ready glow plug clip that I assume just plugs into the 1.2 volt jacks in the panel. I"v read where more than about 2 volts applied to the glow plug will sometimes burn them out. My problem is that I checked the voltage at the 1.2 volt jacks and found there was about 7 volts coming from it. Any
ideas ? Thanks in advance for your help.
