RE: What engine comes on a Troy bilt weedeater? Its a ryobi 31cc Lets convert it!
What size prop will work best on this engine? Looking to put in the Dynaflite SE5a. From what I have seen so far on the forum most people are using a 18x8 or 18x10. What about a 16 to 17 inch prop?
I think I see now how the prop hub works on the long shaft. The hub is basically a spacer. then the prop goes on and a nut holds the whole thing on using the threads already on the shaft. Tell me if I have this right.
Jim
