RE: Os engine, 0.65LA fuel consumption
the best bet is to have someone with some good experience look at the engine as far as adjustments, did you set it up or did someone else (instructor?)
As far as the cluck it should be touching the bottom of the tank, and as said above it should be about a quarter inch from the back or as far as it needs to be so it doesn't touch the back of the tank!
Good luck,
Austin
