RCU Forums - View Single Post - Best way to measure engine thrust angles??
Old 02-27-2002 | 03:44 PM
bitstream
Default Best way to measure engine thrust angles??
I've got a Goldberg Extra I bought already built a couple of years ago. Finally getting around to flying it. The specs call for 2deg right thrust, and 1deg down thrust for the engine. I'm not sure if any thrust was already built into the firewall. So, what is the best way to measure this? Also, any tips on installing a pull-pull rudder system (routing the wire, setup, etc.)?
Thanks!!
