RE: Powermax Trigger Valve -- New Source
IT WORKS
I got the 101 valve today and was able to modify it and make it work it was not that bad the hardest part was removing the pucture pin which was a roll pin i broke several bits and finally got a 1/4 hole milled 3/8 in deep made a 1/4 plug with a 1/8 hole and 1/8 tube added a bit of hysoll and pressed it all together cut the brass tube to correct depth and install on can viola it squrits fuel
Arden
