RCU Forums - View Single Post - Twisted Wire Servo Extensions
Old 09-26-2007 | 05:59 AM
RCISFUN's Avatar
RCISFUN
My Feedback: (44)
Default RE: Twisted Wire Servo Extensions
In short "Noise cancellation"
From a goggle search...
Twisted-Pair Cable
Twisted-pair cable is a type of cabling that is used for telephone communications and most modern Ethernet networks. A pair of wires forms a circuit that can transmit data. The pairs are twisted to provide protection against crosstalk, the noise generated by adjacent pairs. When electrical current flows through a wire, it creates a small, circular magnetic field around the wire. When two wires in an electrical circuit are placed close together, their magnetic fields are the exact opposite of each other. Thus, the two magnetic fields cancel each other out. They also cancel out any outside magnetic fields. Twisting the wires can enhance this cancellation effect. Using cancellation together with twisting the wires, cable designers can effectively provide self-shielding for wire pairs within the network media.
