RCU Forums - View Single Post - MATRIX BUGGY ?'s
Old 09-26-2007 | 06:19 PM
mattyb13
Default MATRIX BUGGY ?'s
1. I seem to have a lot of sag in my suspension. My shocks seem to not have much action in them. I am trying to balance a low cg with enough ground clearance for jumps. I have 30wt and #3 up front and 35wt and #3 out back. Still, is seems as though my shocks are not that dynamic. Any thoughts or suggestions here?
2. I just disassembled my buggy to redo my diffs, clean the buggy and replace the motor. LOTS of my bearings seem to be seized and need to be soaked in wd and then re lubed to get good spinning action out of them. Is this normal? I am using a VERY small amount of trinity bearing oil to lube my bearings but thats oil and that attracts dirt no matter how little I use. Any thoughts on this?
3. What do you guys use to clean your buggy's? I made a solution of 1/3 simple green, 1/3 denatured alcohol, and 1/3 wd40 and I do not like it at all! Any suggestions here?
4. I am about to drop in a new motor and want top performance out of it. can you guys suggest THE definitive break in guide for me? THNX
