RCU Forums - View Single Post - sig kadet ARF antenna
Old 09-26-2007 | 06:36 PM
KitBuilder's Avatar
KitBuilder
Default RE: sig kadet ARF antenna
ORIGINAL: ccab17
where is the best place to put the antenna? Perhaps run it through the bottom of the fuse? Ideas and maybe photos of what you do would help! thanks.
Also, is it normal for someone's first plane to have a few cosmetic errors and imperfections? What did you mess up on, on your first plane?
I usually run mine out the top behind the wing with a stress relief where it exits the back window. If running underneath it seems more likely to get damaged during the inadvertant tall weeds landing etc off the runway...
The very R/C first plane I ever build when I was 14b, I put the shear webs on wrong and had to re-do them not realizing the were to ge between the spars.. don't ask where i put them [X(]. The covering job wasn't the greatest but it looked ok. It was the M.E.N Trainer, Undercamber wing 3-channel.
Mike
