RE: sig kadet ARF antenna
I ran mine out the top of the fuse behind the wing and just drilled two holes in the rear fin. Then stuck the wire through one hole and then through the other. Just make sure that the holes arent too big, just big enough so that the wire will go through. I keep a little bit of slack in the wire so it doesn't pull. I've also got other planes that have tubing inside the fuse. Either way works.
