Speed Control Problems - Help!
Where is the ESC plugged into on the receiver? Should be plugged into the channel used for throttle (most likely channel 3) and not the one that says battery. Sounds like you are getting the power surge when you turn the receiver switch on causing a momentary motor rotation and then have no throttle control.
