RE: Average Rx mAH use per flight?
Mr Matt
I'm around the same with Ni cells 270-350 per flight.
With Thunderpower Li-Po's on a PB Sensor switch I'm less, around 120 per flight each pack...it averages out to 200mAh total as the two packs take different amounts (showing a true dual powerunit) often 120 in one and 80mah in the other. This is with 9 digitals (JR)
Regards
Dave
