RCU Forums - View Single Post - Suhloi with LS-50 engine.
Old 09-27-2007 | 09:17 AM
rctom's Avatar
rctom
Default RE: Suhloi with LS-50 engine.
Here is a note from the manual;
Be sure that the hatch and the cowl are securely attached when you attach the canopy. The canopy will tend to hold the hatch in its set position, so if it’s not mounted on the plane it’s possible that you could build in a twist that will make the hatch fit poorly.
TF
