RCU Forums - View Single Post - Water landing
Old 09-27-2007 | 10:47 AM
bzyguy01's Avatar
bzyguy01
Default RE: Water landing
Thanks for the comps guys!
Strangebrew....That is a Good package to float fly with...You'll be hooked no doubt. One more thing to mention here for you since you have never flown this bird off water....Once you get it in the air it will have a different feel than your use to as it will have a heavy pendalum effect and will not roll the same nor will it turn the same...you may need to use some rudder in your turns if you don't already....give your self some extra height when doing rolls and inverted stunts just in case she gets alittle loose on ya. Hope this helps better prepare you.
Shayne
