RCU Forums - View Single Post - FM Vs. PCM
Thread: FM Vs. PCM
Old 09-27-2007 | 01:38 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: FM Vs. PCM
Fastsky,
If you are going to use your existing receivers then the decision is already made for you. It will be more than likely that you will have to go with the FM version. The PCM radio requires that you use a Futaba PCM receiver. I'm going to take an educated guess that the current receivers you have are not PCM. If that is the case then you will need to get the FM version of the radio.
Ken
