RCU Forums - View Single Post - Programmer or servo problem?
Old 09-27-2007 | 03:43 PM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: Programmer or servo problem?
I bought the programmer 12-29-2006. Date code on the little green sticker is; 06.10 It has the latest progamming as far as I know, no version number is displayed on startup.
I went and bought another new 5625 and it's doing much the same thing, but a combination of what the other two are doing. Program reset went just fine, tried to do a center/endpoint adjust and it failed 4 times before finally going to that screen and now it's displaying "-8211" in the window. The difference in this one is that it doesn't flash to the appropriate numbers which IIRC is 0-225? As you rotate the dial it goes from 8407 to 7900 something.
Sounds like the programmer?
edit info:
I called tech support and talked with one of the guys about this and I'll be sending the programmer in for a look see.
Thanks Mike!
