ORIGINAL: dubflyer
Hi Mark,
I opened my parcel with the venom 45 and found the engine mounting bracket bent where it oviously came in contact with something hard as the coating is also damaged on the edge.[sm=disappointed.gif]
The box looks OK however I need a new bracket as I do not want to risk bending the bracket as it will fracture and fail. I am unable to insert the bolt through the bracket due to it being distorted. see picture below.[sm=spinnyeyes.gif]
How can I get a new brocket..??[sm=drowning.gif]
Thank you,
Martin
Hi Martin!
NOT A PROBLEM!
I have your address here and I'll send a replacement mount tomorrow... I guess the Post Office turned the Gorillas loose on your package!
Please do not run the engine with the mount like it is. There's an extreme "possibility" that it will break from the engine running.
