RCU Forums - View Single Post - Help needed for line of servo's
Old 09-27-2007 | 11:07 PM
Bad_Daddy's Avatar
Bad_Daddy
Default RE: Help needed for line of servo's
Well, the prices look pretty good. However, you really should fix the torque spec on the red servo because 1.5 g.cm is not correct (kg.cm) and it would probably help your sales if you provided the equivalent specs in imperial units, as many of your buyers are unwilling to do their own math.
