RCU Forums - View Single Post - Help needed for line of servo's
Old 09-28-2007 | 12:15 AM
SportCrystals
Default RE: Help needed for line of servo's
ORIGINAL: Bad_Daddy
Well, the prices look pretty good. However, you really should fix the torque spec on the red servo because 1.5 g.cm is not correct (kg.cm) and it would probably help your sales if you provided the equivalent specs in imperial units, as many of your buyers are unwilling to do their own math.
You are correct, it is in kg on all, my type-o.
