RCU Forums - View Single Post - header lenth
Thread
header lenth
09-28-2007, 05:03 AM
6
hosnoopy
RE: header lenth
The chamber you have is a normal pipe the WTC chamber has a shorter front cone.
I run my WTC setup 10mm back from were the O rings leek giving a length of 15" from the outside of the port. This is on a self mod 26zen running a MW3 just drops of pipe in a sharp turn.......
Running a normal chamber on a WTC header will give you a 16" pipe length at the least.
Go as short as you can without letting the O rings leak were the bend has been formed..
Running smaller props would need shorter lengths gepending on your setup. Good luck
Reply
Like
hosnoopy
View Public Profile
Send a private message to hosnoopy
Find More Posts by hosnoopy
View iTrader Profile
