RE: heli max question
I you bought it new go back through the manual and set all the servos per the manual. If you did not buy it new you can still download the manual from helimax. Make sure all your throw directions and amounts are correct. Set your tracking this will also tell you if your pitch is in the right direction. You should see Heli wanting to lift as you check this. Keep trying you will figure it out and start having alot of fun with it.
