RE: Pull/Pull cable dependable
About all I ever use on my big planes (also on some of the very small ones) is pull-pull cables on both elevator and rudder and have never had a failure in some 15 years of using pull-pull. The comments above of being sure that there is just a bit of positive Ackerman is a good and valid one. Also, leave the cables as loose as possible, just enough tension to have no slack at neutral position.
