RCU Forums - View Single Post - Need advice for a first float plane
Old 09-28-2007 | 12:18 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Need advice for a first float plane
Personally, I think the best seaplane out there is the Seamaster (Or the Neptune which is basically the same plane)
It is not as glamorous as a Cub or Beaver, but a single flying hull is MUCH easier to take off and land with in water than a set of floats.
Also, is it safe to assume that you have a boat on this river? The bad thing about rivers is that if you dunk it, it can be miles downstream if you don't have a boat ready!
