RCU Forums - View Single Post - crashed, need help to diagnose problem
Old 09-28-2007 | 03:56 PM
opjose's Avatar
opjose
Default RE: crashed, need help to diagnose problem
As you noticed it was going in, did you note if you had any movement of the other control surfaces.
I know that when something like this occurs, it's next to impossible to pay attention to anything else, but it could help eliminate the radio gear.
e.g. a bad servo or a disconnected servo.
I had a Hitec servo recently that would work perfectly on the ground and usually in the air.
However when the engine hit a certain RPM the servo ( which was on the tail away from the engine ) would go nuts.
At first I though that this was flutter or due to excessive speed.
All interconnects were fine and if I reversed the connections ( I had two servos on the tail ) the problem remained with the servo.
Swapping it out for a new one fixed the problem.
