RCU Forums - View Single Post - Blade Static & Dynamic Balance
Old 03-14-2002 | 05:31 PM
bwoeb
Default Blade Static & Dynamic Balance
Vance,
The reason the above situation works is because that mass that is hanging from the blade grip is designed so its GC is in the same location as the CG for the blade side. It IS possible to get the CG of two completely different shapes to line up in the same position relative to the spin center. But the fact that they AREN'T lined up in the two bladed system is the problem.
Brian
