RCU Forums - View Single Post - Futaba 12z - Option to use all 14 channels on receiver?
Old 09-28-2007 | 08:41 PM
Kelly W
Default RE: Futaba 12z - Option to use all 14 channels on receiver?
ORIGINAL: mr_matt
seeing is believing.
Exactly...
Since I ready your earlier posts on the 12Z, and other info elsewhere, I got really excited. I've always discounted the G3 units value for jets due to the issues raised over noise. Now that you can get all the channels you pretty well need on 1024 with an expander, the 12Z suddenly looks like a pretty attractive radio!
Did I also read that the 14MZ can use 2 of the MPDX-1 units, while the 12 only allows for a single expander, is that correct? Whats your experience with the expander so far Matt? I understand you can adjust endpoints, but the instructions weren't all that clear. For example, can you set the center position? Also, the expanded channels are not available to any mixes in any way? Does that mean driving them with a mix, and driving other channels with an expanded channel?
Lastly, the delay. Does this refer to an offset in control input from the time of input to a reaction, or is this just a servo slow function? Just curious if this could replace a gear door sequencer...
Thx,
Kelly
