Sig Mid-Star 40 - Roll problem !
Hello...
i just checked the lateral balance of the wing only (not mounted on the plane) and one side is a little heavier than the other side.
i have to put about 2 quarters on one side to make it balance. But that doesn't seem a lot to me , considering that the plane has a really fast roll to the left. Maybe i have a combination of many factor affecting the flight. Should i check lateral balance of the wing only, or better to do lateral balance of aircraft with wing bolted on it ? or maybe i should do both ? wing and a/c ?
My os 46 fx in mounted straith up, so the muffler in on the right side, and is probably affecting lateral balance.
