RCU Forums - View Single Post - Haner 9 twist 60 problem
Old 09-29-2007 | 12:10 AM
jaybird11
Default RE: Haner 9 twist 60 problem
suzonka you dont have enough flying time to use switches on your transmiter let alone spoilers on a plane that is not set up for them you turn them on with no wind the plane will drop out on you. You try this and you will crash your plane you have to know just how much to put in if you do use your als and that would start around 3 % if that. You concetrate on flying it in and when to flair and youll be fine if your going to fast slow down this plane flys slow. Until you get better dont fly on real windy days ,sfsjkid has the rite idea.
