Pattern throttle management
One of the things your trying to achieve is constant speed, so basically you would have a throttle position at level flight, and add power for up lines adn reduce power on down lines.
There are things that could cause your trim change not sure what but if you have a computer radio you could do a mix between the throttle and the elevator.
Steve Maxwell
