RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 09-29-2007 | 12:19 PM
  #6109
davepa
Default RE: U-Can-Do 3d 46?
Why do you say thats a waste of good servos and they have more power than i need.The manual calls for 50+oz-in for the ailerons and the elevators and 90+oz-in on the rudder.If i run the 3010's on 4.8 v they produce 72 oz-in which will be enough for the ailerons and elevator but not quite enough for the rudder.If i run them on 6 v they produce 90 oz-in which will be enough for the rudder and more than enough for ailerons and elevator.Plus they are only 22 bucks apiece instead of 100 bucks apiece for digitals that the manual says you need.What would you suggest for servos. Thanks
