ORIGINAL: sledn1000
I loaded the FS one and the 1.07 update and calibrated the controller-all seems well (plane controls,audio and video)except the flight only lasts about 5 seconds(plane nor computer is crashing).Plane controls all seem well,but I have to relaunch even though the plane never got near the ground.Any Ideas why??
Are you using the TacCon or your own Tx? If using the TacCon, be sure to activate every switch and button, including the InstantUp and Reset buttons as well as the toggle switches. If you are using your own Tx, be sure to move each channel input through its full range and then center it before completing calbration. Sometimes, if everything is not calibrated properly, the InstantUp or Reset function will be tripped inadvertently.
If this does not solve your problem, provide more details -- which plane are you flying at which field and what exactly happens when the plane crashes? Is it flying along and suddenly apprears on the ground? Or is it something else? It may be resetting to the ground, which can be fixed through a full and proper recalibration.
Give some more info and we'll try to get things working for you.
