RCU Forums - View Single Post - Throttle Return Problems
Old 09-30-2007 | 05:43 AM
jetmech05
Default RE: Throttle Return Problems
disconnect the pushrod from the throttle servo double check for binding. If ok start the engine and see if the engine returns to a good idle mechanically.if it consistantly returns to a good idle then it sounds like your servo is weak or bad.
