RCU Forums - View Single Post - Is it an acceptable practice to
Old 09-30-2007 | 10:26 AM
seanreit's Avatar
seanreit
My Feedback: (60)
Default RE: Is it an acceptable practice to
By the way, the smart fly regulator is the best regulator we have tested. The likely hood of one of our jets ever getting to even 7amps sustained for more than 5 seconds is not very likely. Most of my jets fly on one battery, one switch, and one duralite or MPI regulator.
I have never had a glitch, but I make sure there is no binding on any of my control surfaces with an amp meter on every jet.
It is well known that I am a full throttle pull hard in the turns kind of guy. If there was going to be a connector failure, or battery problem, I would have found it in the last thousand flights.
Also, I fly all 2.4 in four jets. Never had a receiver reboot.
In my lightning, I did go to two batteries as there was one control surface I could not get to do what I wanted without it sitting neutral at half an amp. I didn't want to keep half an amp draw on one battery and when I added the second, physics worked and cut the draw in half.
