RCU Forums - View Single Post - switch 3 blade prop to 2 blade?
Old 09-30-2007 | 07:01 PM
bruce88123
Default RE: switch 3 blade prop to 2 blade?
Well, the plane should have an Evolution .46 so an 11x6 should do just fine on it. If you want to use a spinner you will probably need to remove the flywheel. It can be carefully pressed off the prop drive hub and the hub reinstalled. Don't lose any pieces.
