RCU Forums - View Single Post - Cowl fitting (AGAIN)
Old 03-23-2003 | 08:51 PM
David_Moen
Default Cowl fitting (AGAIN)
Hi all!
I finally worked up the courage to fire up the dremel and start carving up my cowling.
I've attached a picture showing the bottom of the cowl with the cutout that I've made for the engine.
It is my plan to extend the opening that I have now all the way back to the rear edge of the cowl as I will have to slip it over the stock exaust to install it once the exhaust is in place.
Is this how you would do it?
