RCU Forums - View Single Post - Need Help! Webra 80 ductfan engine
Old 10-01-2007 | 04:44 PM
VF169OPSO
Default RE: Need Help! Webra 80 ductfan engine
I had a Webra 80 that behaved in a similar bad fashion. The idle mixture needle would close during the run due to vibration. The idle and high speed needles need to be balanced to work correctly. The first fix was to make a cylindrical sleeve and use it as a solid stop on the idle screw. The final fix was to replace it with an O.S. engine.
