RE: Newbie problem with engine
great .a is the throttle arm.b i really can't tell but might be an air bleed screw for adjusting idle mixture.c is the idle stop screw for the carb barral,just back it out till the carb closes completely and lock it down.d is the topend high speed mixture needle valve.hope this helps ya
