RCU Forums - View Single Post - engine woes.
Thread: engine woes.
Old 10-01-2007 | 05:56 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: engine woes.
On a cowled engine, you need an exit hole for the air. The air passing around and cooling the engine expands with the heat so you need a larger exhaust opening. The rule of thumb is your exit area needs to be at least twice the size of the inlet area.
