I made it myself. After a bit of damage due to hitting some power lines, the plane looked like a total loss. the wing was gouged pretty good and the fuse was all but worthless. I got talked into trying a repair job but I knew I couldn't fix the wing but one of the more experienced guy's offered to fix it for me. I had the fuse as a challenge to repair. The covering was so damaged I ripped it of and kept it bare wood, nicely sanded and a piece of thin aluminum flashing for the tank cover did the trick. Anyway, I came up with the bright idea of a "War Stick" and here it is:.............................
BTW, it's set up with a OS 55 AX. Thanks for the feedback guy's.......B-
