RE: First conversion Weed Eater 25
Just make sure you keep your radio eqiupment at least 9" from the motor if you are going to be using the stock ignition. Do not use metal clevises to link the throttle servo to the throttle. The muffler you plan on modifying is fine. I don't have that engine but I believe mounting that engine isn't that hard. Good luck![8D]
