RCU Forums - View Single Post - Prop Crud!!!
Thread: Prop Crud!!!
Old 03-26-2003 | 12:17 PM
coomarlin's Avatar
coomarlin
Default Prop Crud!!!
I wouldn't recommend using a drill bit to enlarge the prop hole. It's just not that accurate. Too much margin for error. A prop reamer does the best job because it assures you have the hole centered perfectly. If you must use a drill bit make sure you use a drill press instead of a hand held drill. That will increase your accuracy a bit.
Originally posted by twostroke
I use a drill bit to make mine bigger then balance
