RCU Forums - View Single Post - Propeller balancing
Old 10-02-2007 | 06:20 AM
Dr1Driver
Default RE: Propeller balancing
I take a small Dubro teeter balancer with me whenever I'm buying props. If the prop bangs down to one side, I dont buy it. If it swings down gently, it's ok to balance.
I do not recommend sanding a prop to balance it. A light spray of clear poly-u on the light blade will usually balance most props. If it needs more than that, don't use it.
Dr.1
