RCU Forums - View Single Post - Speedy Bee Tuck
Old 10-02-2007 | 07:11 AM
Scar's Avatar
Scar
Default RE: Speedy Bee Tuck
Two things occur to me. One's the radio, the other is the wing mounting.
If your radio isn't given to twitching the elevator, then I would suggest you secure the back of the wing so it doesn't lift off in flight. Perhaps a screw, or tape, or additional rubber bands.
We see a similar phenomena on high wing planes with rubber band mounts. With only four rubber bands, the front of the wing will lift, and the plane will climb abruptly (usually during a maneuver.)
In a similar fashion, the lift from your wing could be causing it to lift at the trailing edge, causing the plane to dive.
Good luck,
Dave Olson
