After we saw the postings about the Goldberg 67" Edge and 67" Yak ARFS having in-flight failures, we took some time to investigate the claimed problems in these two models.
We found that some hardware was not up to our standards. It is our belief after thorough testing that this original hardware was the cause of the in-flight failures. We are in the process of adding new hardware and a Product Improvement Sheet to all of our in-house stock as well as sending these out to Great Planes Dealers and Tower customers.
As you can imagine, this is a large undertaking and we ask for your patience while we make up these hardware packages and get them sent out. Attached is a copy of the Product Improvement Sheet so that you can see what is being replaced. If you have built your model with the original hardware, please do not fly your plane again until you receive your replacement parts.
As always, if a modeler has a problem with any of our products, they should contact Product Support- 217 398 8970 - 8:00 AM to 5:00 PM CST. Each incident will be thoroughly reviewed. Our support staff should be able to help you resolve your difficulty. If you believe your model has a difficulty that is a result of its original manufacture, it can always be sent to Hobby Services. Here are the return instructions:
http://www.rcuniverse.com/forum/m_1154095/tm.htm
67" Yak 54 ARF
Please replace all of the included Control Horn Bolts in the
kit with the items in this bag:
Four 4-40 x 2-1/2" [76mm] Counter-Sunk Phillips Head Screw
(Aileron/Elevator Control Horn Bolts)
One 4-40 x 3-1/2" [89mm] Threaded Rod
(Rudder Control Horn Rod)
67" Edge 540 ARF
