RCU Forums - View Single Post - Pump with non-pump carb
Old 10-02-2007 | 10:07 AM
  #47
DarZeelon's Avatar
DarZeelon
Default RE: Pump with non-pump carb
ORIGINAL: gkamysz
No! The main needle is not doing all the metering at part throttle. It has some influence but it is not the primary control.
Both of you have to realize that both needles influence the part throttle mixture.
Greg,
While both needles do have an influence on the flow of fuel all across the RPM range, the high-speed needle has absolutely no effect on the part-throttle fuel metering.
Its influence is fixed; not variable, which it needs to be to affect the metering.
